$85 Amazon expansion tank.
Mscromer
Has thanked: 29 times
Been thanked: 15 times
Didn’t want to pay $600+ for an expansion tank so I found this one on Amazon for $85 and thought I’d take my chances on it. I was afraid it was going to be thin flimsy plastic but it’s just like the Porsche one. Very impressed with it so far.
https://a.co/d/09TAL5IQ
t36
Has thanked: 87 times
Been thanked: 33 times
it looks really nice! keep us in the loop. I just finished bleeding my system so by the time I feel like bleeding it again will be ample time to give a review ha ha
Mscromer
t36 wrote: Tue Jun 02, 2026 5:52 pm it looks really nice! keep us in the loop. I just finished bleeding my system so by the time I feel like bleeding it again will be ample time to give a review ha ha
I’ll be installing it this weekend. I’ll let you know after running it for a while. By the way you should get one of these. Makes filling the coolant system a breeze. No need to “bleed” the system.
https://a.co/d/0fE3eVWU
pizatski
Has thanked: 28 times
Been thanked: 18 times
Consider me interested in this reservoir as well.
Regarding the vacuum coolant fill system: I use that same one and find I still have to bleed some air out of the system, but it really cuts down on how much air needs to be bled.
- Patrick S.
1986 944 Turbo
2011 VW Touareg TDI
PCA Chicago Region
fasterfaster
Has thanked: 160 times
Been thanked: 21 times
I bought what I imagine is the same unit off of AliExpress. Recently fitted. No problems sealing so far, even though I'm having an overheating problem and for sure pressure tested it to the full 15psi of my rad cap.
Fitment wasn't perfect and had to yard on it a little bit (maybe 5mm) to line of the 3 mounting points, but nothing that felt too extreme.
I've got my old one which functions perfectly but is a very authentic shade of brown/yellow if someone wants a good deal on an factory unit.
edit: I've been using the Vevor pressure tester, and it's been great for both testing and bleeding. I trust it more than a vacuum bleeder as it stresses the seals in the right direction. I ended up with an extra one through a Vevor error, and they didn't ask for it back, so that's also up for grabs to a community member - preferably local to SF Bay Area.
Marc
88.5 951 M030 Red on Black
facboy
If you can see the coolant level through the tank is it even a real 951 anymore? :think:
t36
Mscromer wrote: Tue Jun 02, 2026 5:58 pm
Great tip. I have the stant version of it. It’s a fantastic tool. I’ve found that These cars have so many internal vertical lips that even with a pressure test in the fill process they need a number of bleed cycles to truly get every last bit of air out.
EDIT: just realized that’s a true vacuum filler. Yeah you are right. That tool is amazing and I should totally get one ha ha
