LWBS (918 Seat) Switch Bezel
Been thanked: 4085 times
Goof wrote: Mon Apr 14, 2025 3:00 pm
Tom wrote: Mon Jan 27, 2025 8:10 pm I took the STL down unfortunately. I was worried about misuse. :shock: Truth is, you need a resin printer to make them look good anyway. I can make them for $20 each or $35 a set. Email me at [email protected] and we can work something out. :)
Sir, I'd like to buy a few set after breaking the driver-side bezel on my LWBS installing the Exclusive Option bolster protectors! I sent you an email to what you supplied above the other day, so you can just respond to that.
Thanks!
Thanks, I was a little thrown off by how many you wanted, and forgot to respond... I'll pull up your email and reply now.
#21
Racer_eX
Just broke mine installing my edguards. Strange as I've done it before with no issues. Are you still making this part? Thank you!
#22
Has thanked: 4525 times
Been thanked: 2453 times
Racer_eX wrote: Sat Aug 23, 2025 10:16 am Just broke mine installing my edguards. Strange as I've done it before with no issues. Are you still making this part? Thank you!
Welcome to Carpokes!
See Tom's instructions at his post further back on this thread for ordering instructions:
viewtopic.php?t=3169&start=10#p41395
I need to make another batch or three. That will take a couple of weeks realistically but I'll get on it. I think I will also try to get crazy Eddie to do a video specifically on popping the bezel free. If you do it the way he shows, there is virtually no risk of breaking one.
#24
Racer_eX
I could use a few of these too. I managed to forget how easy it is to push the adjustment switch out from underneath and instead tried to pull it out. Ugh.
Can I get 4 (1 for now and 3 for future brain fade moments?
#25
I'm making another big batch of these now, and should be able to ship in the next day or two. Send me an email at [email protected] if you need a bezel or three. They are $25 each, or 2 for $45 (raw materials have gone up since the last batch.) Only available to registered Carpokeans! :angel:
Here's a quick video I did showing how to best put them on the switch. They are resin printed and reasonably strong, but the little clips inside are the weak point, so this video shows how to install the bezels without stressing out the clips. :)
#26
Crazy Eddie
Has thanked: 212 times
Been thanked: 78 times
I need a set of these for a customer 🙏
#27
Crazy Eddie wrote: Fri Oct 31, 2025 10:27 pm I need a set of these for a customer 🙏
Just have him email me at [email protected] -- that will be the fastest way I'm sure...
#28
Kevin Hsiung
Thank you for sharing!
I just installed my bolster covers, but unfortunately broke the switch bezels during the process. I was wondering if you are still accepting orders for them.
If possible, I’d like to order 2 sets of switch bezels.
I have sent you E-mails.
Kevin
#29
Kevin Hsiung wrote: Thu May 14, 2026 6:55 pm Thank you for sharing!
Kevin
Thanks Kevin, cc'ing @Crazy Eddie to drive home the need for a warning label or something. :shifty: I've sold quite a few of these even though Ed assures me there is no need to mess with the bezel at all...
#30
