Software tune long-term usage
Did you get a Software tune and if so, do you still have it and happy with it
Yes
2
40%
No
3
60%
Total votes: 5
PBP718
Has thanked: 32 times
Been thanked: 7 times
Tom wrote: Tue Feb 17, 2026 5:24 pm
PBP718 wrote: Tue Feb 17, 2026 5:21 pm
J-Dub wrote: Mon Feb 16, 2026 5:08 pm PSE mod.
Background - Assume you are parked. When you hit the PSE button the exhaust flaps open the car sounds louder, fun. Then you take off and from approx 2000 to 3800 rpm the exhaust valves close again as this is both the common cruising rpm as well as the range that the flat 6 produce the most drone. Then as you accelerate past 3800 rpm the valves open again.
The PSE mod makes it so if you enable the PSE via either the button on the console or the mode on the steering wheel it stays open even during that 2000 to 3800 rpm range. This is where you will notice the drone that is now apparent with aftermarket OAPs.
It is nice to have the option but for me I prefer the factory programing after installing OAPs.
Okay that I knew. I think some valve controllers can do full open, full close or stock PSE like you mention so all three options.
Indeed, including our very own DIY version found here. It does everything the fancy ones will do, and costs less than a tank of gas. Just say'n. :)
It doesn't do everything the "fancy" ones do. Can it change redline? Add free rev in neutral? Remove auto start/stop in normal mode?
2024 Cayman GTS 4.0
J-Dub
Has thanked: 660 times
Been thanked: 568 times
@PBP718 I might be getting confused here. Are you asking about the features of the software tune or the CarPokes valve controller switch?
PBP718 wrote: Wed May 06, 2026 10:54 am
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
PBP718
It seemed you were saying that the carpoke controller does what all the big expensive tunes "do" but my comment is with the tunes, you're getting more than just a valve controller. Maybe I read your comment wrong! 🙃
2024 Cayman GTS 4.0
J-Dub
I think we are on the same page here for the most part. If you want to control the valves you have lots of options including mechanical limiting devices, this switch, the Track Nanny, other external controllers and ECU tunes. If you want to get a ECU tune/calibration you have lots of options and benefits including valve control options.
Jeremy
1957 VW Beetle
2004 VW R32
