Ealokens 951
ealoken
Has thanked: 44 times
Been thanked: 51 times
07k engine rebuild kit
#31
ealoken
Engine parts has arrived from machining.
Assembly in 2026
#32
333pg333
Has thanked: 90 times
Been thanked: 49 times
Exciting. What c/r & boost are you targeting?
#33
ealoken
9:1 and gasoline.
G35-900.
1.5-2bar boost.
600whp
That's my plan, I haven't bought the turbo yet, but a G35-900 is in the scope.
#34
333pg333
What about clutch / flywheel setup? Assuming you have a forged crank.
#35
ealoken
333pg333 wrote: Thu Dec 11, 2025 4:21 pm What about clutch / flywheel setup? Assuming you have a forged crank.
I'm searching for a dual mass flywheel that can fit a Sachs RCS 2 plate organic or similar.
#36
333pg333
Yeah I saw that post on FB today. Bit of a pita learning that now.
#37
ealoken
333pg333 wrote: Thu Dec 11, 2025 10:32 pm Yeah I saw that post on FB today. Bit of a pita learning that now.
Yes, but its the first broken forged crank i have seen.
And it is in a drifting car, so there can be many sources for this.
In terms of vibrations, a 5 syl is never happy :lol:
the 2010-2013 TTRS have a DMFW, 600-1000 euro. But torque limit on 750 nm.
So im kinda inbetween to use my single mass setup og swap to a dual mass.
#38
JHY
@ealoken — I'm curious, did you ever get any dyno numbers on the GTX35?
#39
ealoken
JHY wrote: Wed Dec 17, 2025 6:08 pm @ealoken — I'm curious, did you ever get any dyno numbers on the GTX35?
No, but if we calculate the fuel in the map etc. it was 400 whp on 1,25 bar boost.
#40
