Thermostat Choices in 2025
- Latitude48
- Has thanked: 105 times
- Been thanked: 113 times
I checked the thermostat I purchased from Porsche. It's stamped Made in Germany and is marked Wahler. On the small end it's marked 83 with a degree symbol.t36 wrote: Tue Oct 21, 2025 8:44 amAwesome! Appreciate that.Latitude48 wrote: Mon Oct 20, 2025 5:55 pm I have a new Porsche thermostat 944 106 019 00 I purchased in 2022 for an eventual pump replacement. I'll dig it out and see where it's made, and if it has any temp markings.
My recent purchase from Pelican indicates Made In Brazil and stamped 2022.
My local dealership is bringing one in as well to check. Maybe they have old stock.
Tom Pultz
- Has thanked: 943 times
- Been thanked: 4032 times
I got a thermostat for my '79 450SL last year -- brand new in Mercedes packaging -- and it was marked "Made in W. Germany."Latitude48 wrote: Thu Oct 23, 2025 2:24 pmI checked the thermostat I purchased from Porsche. It's stamped Made in Germany and is marked Wahler. On the small end it's marked 83 with a degree symbol.t36 wrote: Tue Oct 21, 2025 8:44 amAwesome! Appreciate that.Latitude48 wrote: Mon Oct 20, 2025 5:55 pm I have a new Porsche thermostat 944 106 019 00 I purchased in 2022 for an eventual pump replacement. I'll dig it out and see where it's made, and if it has any temp markings.
Interesting! My dealership brought one in and it’s made in Germany. Also built recently.Latitude48 wrote: Thu Oct 23, 2025 2:24 pmI checked the thermostat I purchased from Porsche. It's stamped Made in Germany and is marked Wahler. On the small end it's marked 83 with a degree symbol.t36 wrote: Tue Oct 21, 2025 8:44 amAwesome! Appreciate that.Latitude48 wrote: Mon Oct 20, 2025 5:55 pm I have a new Porsche thermostat 944 106 019 00 I purchased in 2022 for an eventual pump replacement. I'll dig it out and see where it's made, and if it has any temp markings.
Sounds like 944 106 019 00 is made in Brazil and Germany simultaneously.
I’ll test the 4 thermostats I have and post the results !
I tested two thermostats today.
Both of them are 944 106 019 00 (83 degree unit for updated water pump design).
One of them was a Wahler stamped "made in Germany". It was produced in 2020. The other, was a Wahler stamped "Made in Brazil" produced 2022.
The results are staggering.
1) The made in Germany Wahler (sourced from my dealership), opened just below 83 degrees. It opened proudly with lots of room for flow. As it cooled off, it stayed open for a longer temperature range.
2) The made in Brazil Wahler - was just barely open above 90 degrees. It closed up very shortly after it began cooling as well. Way too high a temperature and definitely didn't open enough for adequate flow.
Check your thermostats before installation.
The German made unit is on the left and can be seen open. The Made in Brazil unit on the right. Both in the same water, same temperature, same duration of time.
- IMG_4250.JPG (4.39 MiB) Viewed 453 times
t36 wrote: Sat Nov 01, 2025 4:00 pm I tested two thermostats today.
Thanks for posting this! It supports my fears about the 'new' Wahler units unfortunately. You can stamp Rolex on a Casio, but it's still a Casio.
Absolutely! Thank you! I might order another from the dealership to have as a backup.Tom wrote: Sat Nov 01, 2025 7:05 pmt36 wrote: Sat Nov 01, 2025 4:00 pm I tested two thermostats today.
Thanks for posting this! It supports my fears about the 'new' Wahler units unfortunately. You can stamp Rolex on a Casio, but it's still a Casio.I'm hoping Porsche holds their suppliers to a standard, and that they wouldn't put a part like that in a PCNA box, though I suppose time will tell. Unless/until a new standard bearer emerges, I'll be testing like this before putting any t-stat in my car. Thanks again for the post!
Was the one from the dealership in a Porsche box? That might suggest their quality standards are protecting them from the lesser parts....?t36 wrote: Sat Nov 01, 2025 8:32 pmAbsolutely! Thank you! I might order another from the dealership to have as a backup.Tom wrote: Sat Nov 01, 2025 7:05 pmt36 wrote: Sat Nov 01, 2025 4:00 pm I tested two thermostats today.
Tom wrote: Sat Nov 01, 2025 8:46 pmWas the one from the dealership in a Porsche box? That might suggest their quality standards are protecting them from the lesser parts....?t36 wrote: Sat Nov 01, 2025 8:32 pmAbsolutely! Thank you! I might order another from the dealership to have as a backup.Tom wrote: Sat Nov 01, 2025 7:05 pm
Just a Porsche bag. The classic sealed one. Clear on one side and white printed back with barcode.
I just got a front main seal from the dealership though. Definitely not putting it in my car. Ordered an Elring.
Also, the woodruff / feather key is the wrong size now ha ha. Definitely checked and it is the right part number for crank key. Photo of said seal and key.
- IMG_4231.jpeg (2.64 MiB) Viewed 432 times
- FAAB8752-D1DF-480C-8015-7A355CAF5318.jpeg (564.66 KiB) Viewed 432 times
