I had the same experience. DT40 is expensive but worth it.cavediver32043 wrote: Thu Sep 05, 2024 7:23 am Lokasil and alusil blocks need Molybdenum; a friction modifier to minimize silicon migration out of the cylinders over time which is a big contributor for bore score. 4 years ago I switched from LiquiMoly 5W-40 to Driven DT40 5W-40 Oil. 07CS Manual 52K mi. I pull a UOA sample on my Oil /filter changes and Molybdenum element PPM's with LiquiMoly ran 97 ppm's. With Driven oil Molybdenum ppm's increased to 427 ppm's. Proof is in the numbers.....
Oil brand recommendation
- icb
- Has thanked: 59 times
- Been thanked: 54 times
I use Porsche Classic Motor oil, specially formulated by Porsche for Air Cooled 3.0L and above.
My 911 told me she loves it !
- 012.JPG (113.61 KiB) Viewed 5226 times
- 014.JPG (655.25 KiB) Viewed 5226 times
NormGarr87
- Has thanked: 9 times
- Been thanked: 5 times
I have an 03S and use DT-40 5W/40. I do an oil sample with each yearly change and the numbers look great. I purchased the car in 2017.
Current Fleet
2003 Porsche Boxster S
2024 VW Tiguan R-Line
1981 VW Pickup
1973 VW Thing - long term project
1970 VW Karmann Ghia
1981 VW Pickup
DT40 is an oil that was invented via collaboration between Jake Raby/Charles Navarro/Lake Speed Jr . Somewhere in that mix Joe Gibbs Racing was involved . Some would consider it a boutique oil but it was specifically designed for the 986/996/987/997 series of engines .
NormGarr87
My two cents. I run Driven DT 40 in my 03S. The PO used it so I continued. I have owned my Boxster for 7 years now and all my oil reports have been spot on. My Boxster is a limited use fun machine for the street. I do not track but I REALLY enjoy the NC mountains.
Current Fleet
1981 VW Pickup
1981 VW Pickup
- zooklm1
- Has thanked: 19 times
- Been thanked: 58 times
It might not be a great comparison but in my 968 and 944 turbo I use Valvoline VR1 20-50 racing oil and add a bottle of Liquid Moly Hydraulic Lifter Additive for the 944 Turbo to quiet the lifters. I started using the VR1 years ago when my turbo started using/burning a quart of every 500 miles. When I changed to VR1, oil consumption dropped to the nominal leakage around the oil pan gasket. I had initially thought the turbo oil seals were starting to fail. Answers on several forums suggested to try VR1. VR1 has a higher zinc content than most big name oils but not sure how it compares to the specialty brands.
- Has thanked: 941 times
- Been thanked: 4027 times
Any reason you picked Liquid Molly over a ZDDP/zinc additive?zooklm1 wrote: Tue Jul 29, 2025 7:42 pm It might not be a great comparison but in my 968 and 944 turbo I use Valvoline VR1 20-50 racing oil and add a bottle of Liquid Moly Hydraulic Lifter Additive for the 944 Turbo to quiet the lifters. I started using the VR1 years ago when my turbo started using/burning a quart of every 500 miles. When I changed to VR1, oil consumption dropped to the nominal leakage around the oil pan gasket. I had initially thought the turbo oil seals were starting to fail. Answers on several forums suggested to try VR1. VR1 has a higher zinc content than most big name oils but not sure how it compares to the specialty brands.
In theory, but I was intrigued by your comment about liquid Molly...zooklm1 wrote: Tue Jul 29, 2025 8:30 pm Not really. Would more ZDDP help reduce the lifter noise? Any recommendations?
Lee
