Reg sticker? Peel or stack?
Has thanked: 945 times
Been thanked: 4039 times
Unbelievably, my 992 is a year old and I have the '22 registration sticker to put on. Trying to decide if I should peel off the existing one and start fresh every year, or stack them up... I've seen some old original-owner cars with a quarter inch of stickers, which is kind of cool, but it also looks kind of sloppy. Decisions, decisions...
staceybsnyder
Has thanked: 26 times
Been thanked: 66 times
For me it has been variable based upon the texture of the license plate. Some plates are smoother and the stickers come off super easily. Other plates are more porous with a texture and I've always struggled to get the first sticker from the plate off.
Mostly what i've done is put year two on top of one and then every year remove that 2nd sticker.
For the plates that are super smooth and the stickers come off easily, I'd go back to bare.
On a side note, the loaner car that I have right now for the wife's car has an odd case where whoever replaced it stuck it just about the worst i've ever seen. Made me laugh...
Last edited by staceybsnyder on Sun Mar 06, 2022 11:00 am, edited 1 time in total.
Stacey Snyder
2006 997 Carrera S 6 Speed
2005 987 Boxster Base 6 Speed
1986 Carrera 3.2 5 Speed
audi4t
Has thanked: 385 times
Been thanked: 298 times
Stack in Georgia :P
In Connecticut the state stopped issuing reg stickers a few years ago :?: :?: :?:
audi4t wrote: Sun Mar 06, 2022 10:46 am Stack in Georgia :P
How to the police enforce registration then?
audi4t
Simply read the plate - electronically - auto character recognition cameras without the officer leaving the cruiser
Big brother is everywhere 🤣🤣🤣
You will see police cruisers with multiple devices on the trunk drive by parked and moving cars and check registrations, violations etc
Been thanked: 668 times
Peel if you can get the sticker off. It’s hard to stack them neatly.
Has thanked: 255 times
Been thanked: 251 times
By the time new-sticker season happens here (every couple years in spring) I'm ready to do a serious clean-and-detail, so the plates are off anyway. A little heat (hair dryer, -maybe- carefully with a heat gun) softens the old sticker glue, so careful razor blade technique will get the old one off with no trouble. Clean any glue residue off with alcohol or wax/adhesive remover. Then the new sticker goes on, with placement consideration for how your Carpokes plate frame fits over the plate. Careful wax/seal the whole thing, then back on the car after it's been waxed/sealed.
How many people run plastic shields/covers over at least the front plate? For my cars, I work hard to keep the front plate low and angled enough to make it just a bit harder to read from a traffic cam up on a pole. Not much chance anybody out in the wild knows how the front plates fit on my car anyway, so my no-drill mount that holds the plate tight to the front apron below the nose is the way it came from Germany. My front plate covers are permanently stained inside by brown road deicer and red cinders that the car itself has never driven through. I have no idea how that got there, and it doesn't wash off officer. Same as the front plates on your cruiser... Anyway, they are hard to read at best at ground level. Most cars driven in the winter here have similar staining on plates themselves if they aren't kept clean and protected with at least paint sealant.
I don't drive fast any more, so no worries here generally. :mrgreen:
SoCal 928 Group Cofounder
elm310
Has thanked: 271 times
Been thanked: 92 times
I usually stack and wait until I have about 5 of them and then I peel and stick a new one on.
Eric
2022 911 Carrera 4 GTS
2009 BMW e92 M3
2014 BMW f10 535i
2017 Nissan Frontier SV
2019 Yamaha AR210 Jetboat
Jsmit197
Has thanked: 89 times
Been thanked: 19 times
It's dependent on the state you are in and how easy you can get off. I usually try to remove every few years when get a few on. JS
2022 992 911 Turbo S
2018 718 Boxster GTS 2.5 Cabriolet
Past:
2018 Panamera 4S
