Need MaxxECU base tune
- chris white
- Been thanked: 175 times
BTW - the ground signal from the ECU is quite short - hard to measure on anything but a scope
- chris white
BTW - plan B is to let your buddy hold the spark plug and you can judge the signal strentgh by how loud he screams at you.
- Has thanked: 4455 times
- Been thanked: 2417 times
chris white wrote: Wed Apr 16, 2025 7:49 am BTW - plan B is to let your buddy hold the spark plug and you can judge the signal strentgh by how loud he screams at you.
Here are my ignition settings in case anything jumps out.
As far as I can tell everything is registering correctly. I’m seeing good RPM, IAT, CLT, trigger sensors.
- IMG_7219.jpeg (1.62 MiB) Viewed 1750 times
- IMG_7220.jpeg (1.48 MiB) Viewed 1750 times
cda951
- Has thanked: 136 times
- Been thanked: 81 times
That "output voltage" setting of 5V seems like a good place to look, 944 coil needs 12V. This also could explain the dim test light.
Post a screen shot of the other options in the output voltage drop-down menu.
Chris A.
---'86 944 Turbo track rat
---'74 Jensen-Healey roadster
---other stuff
---other stuff
- chris white
is the ECU powering the coil? the 5v setting seems odd - you mentioned that you were reading 12v at the coil.cda951 wrote: Wed Apr 16, 2025 6:41 pm That "output voltage" setting of 5V seems like a good place to look, 944 coil needs 12V. This also could explain the dim test light.
Not sure what the 5v setting means?!
I don’t know, yetchris white wrote: Thu Apr 17, 2025 8:01 amis the ECU powering the coil? the 5v setting seems odd - you mentioned that you were reading 12v at the coil.cda951 wrote: Wed Apr 16, 2025 6:41 pm That "output voltage" setting of 5V seems like a good place to look, 944 coil needs 12V. This also could explain the dim test light.
- chris white
yes, it is. so i wonder what the 5v setting it for?
