$500 shipped
I'm selling the Vitesse V-MAF+ (with MAP) kit that I had installed for a short while (purchased 2023). I'm looking into standalone options and want to sell the MAF kit first to gather the funds.
This is the "stealth" kit, which means you use the factory airbox for a more factory appearance. Everything that is included is what I received from Vitesse Racing. The only modification I made was to epoxy a honeycomb to try and balance out the airflow to the MAF. You will need to have a 3.0 bar FPR installed.
You will get:
Printed instructions (they are usually just digital format from Vitesse)
-This includes the "dip switch" instructions that are specific to THIS kit **do not lose these instructions!!**
Adapter that attaches to factory airbox + hardware (Plus a spare adapter)
MAF (and wiring) + tube that goes between airbox and j-tube
MAP sensor and wiring
4 Injectors (I believe they are 80lb)
DME chip
**SOLD** Vitesse "Stealth" V-MAF+ Kit for 944 Turbo
- NCGermerican
- Has thanked: 141 times
- Been thanked: 92 times
- Belgian951
- Has thanked: 74 times
- Been thanked: 33 times
Can you remove the honeycomb?
- NCGermerican
It's held in with epoxy to avoid getting sucked into the MAF. I'm sure it could be removed but would take some time to sand off the epoxy.
- BigRatchet
- Has thanked: 4 times
- Been thanked: 2 times
PM's aren't working I think but I sent one
- Has thanked: 4451 times
- Been thanked: 2417 times
One thing with PMs that I discovered is that they won't be sent unless there's text of some sort in the subject line of the initial PM.
- NCGermerican
I received the PM and replied. Thanks!
- NCGermerican
The kit is sold!
- NCGermerican
At this point I’m leaning towards MAXXECU. Seems to be the most DIY friendly and many times the out of the box tune works well enough to not need a tuner right away.ROB III wrote: Fri Feb 28, 2025 7:36 am Congrats! Any decision on what standalone you are going to pursue?
