GTP Valve Cover
333pg333
Has thanked: 90 times
Been thanked: 49 times
Oh, I thought he was in Europe. But in any case he might have the CAD files for the lid still.
Has thanked: 521 times
Been thanked: 265 times
333pg333 wrote: Wed Feb 19, 2025 3:40 am Out of curiosity, why not CNC?
Could be a cosmetic issues as cast and CNC have different finishes/textures.
Not sure how costs would compare.
gruhsy
Has thanked: 48 times
Been thanked: 81 times
Sorry I think I was getting threads and cars mixed up. I believe you are correct.
333pg333 wrote: Wed Feb 19, 2025 1:08 pm Oh, I thought he was in Europe. But in any case he might have the CAD files for the lid still.
333pg333
ROB III wrote: Wed Feb 19, 2025 2:00 pm
I think we're talking about 2 different items here? Michael wanted someone to produce the Le Mans valve cover but also mentioned wanting someone to 'CAD-ify' an intake design of his. In which case I made the suggestion that if he couldn't find anyone over there, the guy that made mine might be able to help. Although I know he's extremely busy. The finish is fantastic though. Although I think the cam cover needs to be cast for a faithful finish.
333pg333 wrote: Wed Feb 19, 2025 11:28 pm I think we're talking about 2 different items here? Michael wanted someone to produce the Le Mans valve cover but also mentioned wanting someone to 'CAD-ify' an intake design of his. In which case I made the suggestion that if he couldn't find anyone over there, the guy that made mine might be able to help. Although I know he's extremely busy. The finish is fantastic though. Although I think the cam cover needs to be cast for a faithful finish.
SIR! You are correct, the confusion was mine..nothing unusual there.. :oops:
Thank you for the correction. :thumbup:
Has thanked: 4481 times
Been thanked: 2435 times
....fixed the formatting/BBcode tags for ya.... ;)
cp99
Has thanked: 4 times
Been thanked: 22 times
Is that a 3D printed intake?
Boston-area, MA
333pg333
cp99 wrote: Thu Feb 20, 2025 4:07 pm
No, CNC billet alu. Although he did do a few partial printed versions prior to pressing the 'Go' button on the big expensive machine to produce a masterpiece. Was a bit tricky fitting it underhood due to runner length and angles. Hopefully it won't be a further issue now that we're changing throttle body to something larger.
Santa Intake.JPG (2.04 MiB) Viewed 1716 times
#18
michaelmount123
Has thanked: 26 times
Been thanked: 179 times
Many thanks for all the input! Re the valve cover, I had reached out to the fellow that did the very nice GTP clone over on RL, but haven't received a response. This is why I reached out on Carpokes hoping for a simple and affordable solution. Anything one-off can be tough.
The same goes for the intake manifold. I'm wanting to convert the 2V GTR engine to 4V while using the original throttle bodies and plenum. This is another challenge since there'd be no demand for this piece.
If any of this stuff were easy, it wouldn't be near as interesting.
BTW, Patrick, your intake is absolutely gorgeous!
#19
Has thanked: 944 times
Been thanked: 4035 times
I've been experimenting with Bambu's PPA-CF, and am fairly sure it would hold up fine as an intake like that. Good to 440F degrees with a tensile strength that exceeds some aluminums, at least on paper. My first few prints with it suggest it's the real deal in terms of printer-to-engine-bay parts. That said, even though Porsche put a plastic oil pan on my 992 :shock: :shock: I still wouldn't want a valve cover in plastic. I assume that GTP valve cover has machined bearing races, with oil galleys, etc.?
#20
