Break-in period?
Has thanked: 936 times
Been thanked: 4023 times
Ok, maybe a dumb question, but does Porsche recommend any kind of break-in period for the Taycan?
Ajjra
Has thanked: 8 times
Been thanked: 4 times
I was told no break-in period by my dealer. Kind of makes sense with the electric motors…
amelen
Has thanked: 5 times
Supposedly no break-in required, BUT some parts have their own pre-built "break-in" - for example the regen breaks won't work at 100% until the breaks are set in. So your efficiency (ie: mileage) improves slightly over time once they are at 100%.
VA_CT
Has thanked: 23 times
Been thanked: 10 times
I read somewhere that for EVs the break-in period is the first 500 or so miles for the car to understand your driving habits. Not sure if this is relevant. I did drive my car conservatively. I get ~215 miles for 85% charge.
baherrick
VA_CT wrote: Mon Feb 07, 2022 10:44 pm I read somewhere that for EVs the break-in period is the first 500 or so miles for the car to understand your driving habits. Not sure if this is relevant. I did drive my car conservatively. I get ~215 miles for 85% charge.
My range is similar. Range increased for about the first month before settling at around 250 miles.
vdr
Has thanked: 9 times
I was never told of any break in period at delivery. FWIW I'm getting a range of roughly 180 miles @ 85% though it is a bit cold here in the NE. Hoping this figure gets significantly better soon...
Ajjra
Weather is a tremendous dictator of range. I do not have the extra performance battery and I also get 180 miles @85% in winter and 250 miles at 100% in summer
So are there 'filling stations' out on the road? If I wanted to take a 400 mile drive to Southern California, is that realistic with an electric car these days? And are all the charging stations the same? My wife has her eye on that new Subaru Solterra....
vdr
This isn't something I've done ....YET... though I do know that some states are more EV friendly than others particularly when it comes to third party charging stations. To my mind CA is one of the leaders in the country in regards to EV charging architecture and I'd think that a 400 mile trip would be an easy thing to accomplish. Simply input the destination into the Taycan's NAV unit and/or an app like ABRP and it will detail the best route and it's optimization for charging along the route. With high speed LV3 charging the stop in this particular scenario would likely be about the same or slightly longer than a normal stop for gas and a snack...
Draman
Been thanked: 5 times
Tom wrote: Fri Feb 11, 2022 8:02 am So are there 'filling stations' out on the road? If I wanted to take a 400 mile drive to Southern California, is that realistic with an electric car these days? And are all the charging stations the same? My wife has her eye on that new Subaru Solterra....
It's not totally impossible, but you have to plan the trip accordingly. I bought my car in CT but had about a 7 month wait for delivery. In the interim, I ended up moving to MD. Once the car finally came in, I went to pick it up in CT and drive it back. It was about 400 miles in the winter, sub 20 degree temperatures at the time. It was my first time driving the car so I had some range anxiety, but I had to stop 3 times to charge. Due to the anxiety, I was typically stopping with 40-50 miles of range left other than the last stop where I was basically empty. That last stop I only needed 7 miles of additional range to make it home, so realistically I should have been able to make it in 2 stops if I had driven a little further prior to the earlier 2 stops. Electrify America is relatively prevalent (at least along the east coast), not sure how it is out in CA. As long as you plan accordingly and hopefully don't get range anxiety the way I did, it's possible but definitely less convenient than an ICE car to take longish trips.
