- Gotti of the Deep
- Has thanked: 19 times
- Been thanked: 13 times
@fjord384 Do you ppf and ceramic coat those or it's not needed since they're covers?
2024 982 CS Shark Blue, 6spd MT, SC, PASM, PTV
Spec'd like it won't be made anymore.
- Pachanga718
- Has thanked: 236 times
- Been thanked: 127 times
CF looks great with that color and the wheels!
So these are actual replacement housings. I would recommend a ppf and ceramic on these.Gotti of the Deep wrote: Wed Aug 07, 2024 5:38 am @fjord384 Do you ppf and ceramic coat those or it's not needed since they're covers?
I re-installed my Numeric pedals. I'm pleased with them. Note that they are large and made of metal, not rubber like the diminutive stock units. So, appropriate footwear is a safety consideration.
I also adjusted my shifter cables to balance the free play between Front/Rear and Left/Right. The cable tweaks cured a not-quite-right feeling in the shifter. It's an easy job to do, with a real potential benefit, and requires only a trim tool.
- 20240803_170526.jpg (3.42 MiB) Viewed 647 times
- 20240806_112541.jpg (389.98 KiB) Viewed 647 times
- 20240806_144700.jpg (2.29 MiB) Viewed 647 times
ReidMcT
The Hills, Texas
'21 Cayman T M6
'17 Boxster S PDK
The Hills, Texas
'21 Cayman T M6
'17 Boxster S PDK
- Has thanked: 4455 times
- Been thanked: 2417 times
I installed the Numeric pedals last year. You are absolutely correct in that there is no comparison between them and the lightweight, barely adequate factory versions. (Your 'diminutive' adjective is perfect.)ReidMcT wrote: Wed Aug 07, 2024 2:14 pm I re-installed my Numeric pedals. I'm pleased with them. Note that they are large and made of metal, not rubber like the diminutive stock units. So, appropriate footwear is a safety consideration.
Earlier in this thread: https://www.carpokes.com/viewtopic.php? ... 340#p26920
- 71eh
- Has thanked: 200 times
- Been thanked: 565 times
Just in from Crazy Ed.
Alcantara Dash ends & Double Stitch leather fuse box covers.
Will try putting them in this weekend.
'24 Porsche 718 Cayman
'21 Mercedes AMG GTR
'76 Triumph TR6
'23 Porsche Macan GTS (sold)
'22 AMG CLS53 (sold)
'22 AMG CLA45 (sold)
'20 AMG c63s (sold)
'76 Triumph TR6
'20 AMG c63s (sold)
They look great!71eh wrote: Wed Aug 07, 2024 3:31 pm Just in from Crazy Ed.
Nice job and hats off to Eddie!!
- J-Dub
- Has thanked: 654 times
- Been thanked: 567 times
Could you describe the cable adjustment process a little bit? In another car, my VW R32, I would lock both the shift tower on the transmission and then the shifter into a fixed neutral position then adjust the cables to have the closest to zero tension. How does the Cayman compare? I have not yet seen a way to lock either the shift tower or shifter, maybe the spring tension is enough.ReidMcT wrote: Wed Aug 07, 2024 2:14 pm I also adjusted my shifter cables to balance the free play between Front/Rear and Left/Right. The cable tweaks cured a not-quite-right feeling in the shifter. It's an easy job to do, with a real potential benefit, and requires only a trim tool.
And my pic of Numeric
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
2004 VW R32
First, don't overthink or try to visualize it all before starting, because it's a job that you come to understand as you do it, and you will realize it is simple, really.J-Dub wrote: Wed Aug 07, 2024 7:37 pm
Porsche makes a jig to center the shift lever fore/aft, in the official position. It's unnecessary, as you will see. You can pick your own preferred tweaks. As for left/right centering of the shift lever, yes, the spring does that.
All you're doing here is popping each cable end out of its connector, finding the middle ground of free play in the cable, and then popping it back into the connector. You can test/adjust how it all feels before snapping the console back together.
If you're a worrier like me, you mark the starting positions as I did with a red pen (barely discernible in photo of right-side cable end).
ReidMcT
The Hills, Texas
'21 Cayman T M6
'17 Boxster S PDK
The Hills, Texas
'21 Cayman T M6
'17 Boxster S PDK
- Has thanked: 3305 times
- Been thanked: 942 times
I appreciate J-Dub's question and thanks for giving folks on here more info, because I know there are likely many members who view this change with trepidation since what is " Simple " for one person, is difficult for another ( I would be one of those anothers ). As you noted, you are a worrier, and there are plenty of us like you, so in this case more info just helps one decide if they want to tackle a job or take to an expert. Thanks for the extra detail, it will help others wanting to accomplish this task, imho.
