Oil pressure and coolant temp in DASH with standalone ECU?
adonay
Has thanked: 2 times
Been thanked: 4 times
So far i have made a custom wire harness going from the the stock oil pressure sender to the 14 pin connector .
Am i right if G on sender goes to pin 6 in the 14pin socket and W on sender goes to pin 9?
And also i am not sure if it is right but should water temperature be on terminal 8 and 10 . Does this sensor have any polarity?
Anything else i have to mess with the 14 pin socket.
I get RPM from the standalone and connected to the red 4 pin socket in the passenger footwell .
