My 944 still has its factory bibblueline wrote: Fri Nov 24, 2023 8:49 amNope - no bibs in any of the Porsche's I currently own or have owned in the past. In fact, I cannot ever remember having a fuel bib on any car I've ever owned. However, I do remember seeing rubber versions here and there a long time ago.Larry C wrote: Fri Nov 24, 2023 8:26 am Don’t 911’s come with OEM bibs? I’m not sure if it adds more safety but I do look forward to filling up the car.
Unlike cars from long ago, many (most? all?) vehicles today have their filler caps set quite deep into a cavity on the body side with plenty of room all around the filler tube to get the fill nozzle hose in correctly. There are also drainage provisions for fuel spillage safety and odor dissipation.
In my opinion, outside of adding something unique to one's car (which is cool for those who want that), there is no remotely urgent or necessary reason for a fuel bib.
- Has thanked: 945 times
- Been thanked: 4039 times
- Has thanked: 4484 times
- Been thanked: 2435 times
They do. This thread is about function AND form - not exclusive to either one. Both are good!71eh wrote: Fri Nov 24, 2023 8:52 amSorry I just assumed people knew I was asking because of the looks, not function. Same with fuel filler caps and tire valve caps.blueline wrote: Fri Nov 24, 2023 8:49 amNope - no bibs in any of the Porsche's I currently own or have owned in the past. In fact, I cannot ever remember having a fuel bib on any car I've ever owned. However, I do remember seeing rubber versions here and there a long time ago.Larry C wrote: Fri Nov 24, 2023 8:26 am Don’t 911’s come with OEM bibs? I’m not sure if it adds more safety but I do look forward to filling up the car.
Some of the posts (mine included) were merely referring to the functionality aspect of bibs and if they are OEM on today's vehicles.
- murphsea
- Has thanked: 83 times
- Been thanked: 123 times
Been busy getting my GT4 ready for the next HPDE on Dec 2nd and 3rd at Roebling Road.
Installed the CMS Roll Bar myself, that was quite the job. Next step is to install the 6 point harness.
Had Autometrics Motorsports put Porsche Motorsport upper strut mounts (from the 991 cup car) and rear toe links and do a track alignment.
They also put GiroDisc brake discs and Pagid RSL29 brake pads on the car.
At this point it didn’t make sense to use the tires from 2021 that I’d given a hard time to on the last track day so it has a new set of Cup 2 tires.
See the old vs new pics below of the upper strut mounts and toe links.
My fastest lap in my 992 base at my first ever HPDE weekend (at Roebling) was a 1:28, second HPDE weekend at Roebling was the first with my ‘21 718 GT4 and I took 7 seconds off that time. Will be interesting to see how these changes make a difference.
2025 Porsche 718 Spyder RS
2024 Porsche 911 GT4 RS
2021 Porsche 718 Cayman GT4
1973 Porsche 914 2.0
Installing the CMS bar yourself is impressive. I wouldn't tackle that out of fear of destroying panels and/or otherwise screwing something up. I know getting them installed is a challenge, so good on you!murphsea wrote: Fri Nov 24, 2023 9:27 am Been busy getting my GT4 ready for the next HPDE on Dec 2nd and 3rd at Roebling Road.
I have the Cantrell roll bar and it is great, but I feel the CMS offers a couple of big advantages, one being a bit of a view out the back window (I have virtually none with the angled Cantrell cross bar that goes from the front of one side to the rear of the other side and the raised wing.)
The other huge advantage, at least for those with a 4RS, is the ability to get the back engine cover off without having to remove the Cantrell bar (or parts of it, anyway). I think the CMS has stronger tubing too.
Hmmm... I think my "Unlike cars from long ago..." comment covers my behind in that regard!Tom wrote: Fri Nov 24, 2023 9:17 amMy 944 still has its factory bibblueline wrote: Fri Nov 24, 2023 8:49 amNope - no bibs in any of the Porsche's I currently own or have owned in the past. In fact, I cannot ever remember having a fuel bib on any car I've ever owned. However, I do remember seeing rubber versions here and there a long time ago.Larry C wrote: Fri Nov 24, 2023 8:26 am Don’t 911’s come with OEM bibs? I’m not sure if it adds more safety but I do look forward to filling up the car.
In my opinion, outside of adding something unique to one's car (which is cool for those who want that), there is no remotely urgent or necessary reason for a fuel bib.![]()
- murphsea
I got the CMS one because of the items you mentioned with visibility and engine access.blueline wrote: Fri Nov 24, 2023 9:40 am
The other huge advantage, at least for those with a 4RS, is the ability to get to the back engine cover off without having to remove the Cantrell bar (or parts of it, anyway.) I think the CMS has stronger tubing too.
Also, they sell OEM trim pieces already cut for the roll cage which is great.
Happy I was able to do it myself and it worked out but probably won’t do the install myself on my GT4 RS when that arrives next April. Haven’t even hit the freeze point yet.
- M5-Mike
- Has thanked: 55 times
- Been thanked: 35 times
[/quote]
[/quote]
I noticed that "long ago" crack, but decided not to waste a retort on such youth.
[/quote]
2017 Cayman S, 2013 X1M, 2013 Cayman S, 2010 135is, 1999 CLK AMG, 1991 M5, 1989 327is Spec E30, 1988 928S4, 1985 4Runner, 1975 914, 1969 Datsun PU, 1957 Belair, 1948 Divco milk truck
Ahhh youth...where hast thou gone!!!
- Larry C
- Has thanked: 592 times
- Been thanked: 668 times
My friend’s 911 SC has the original OEM fuel filler bib. They still sell them at Pelican Parts for many 911’s.
Nice!murphsea wrote: Fri Nov 24, 2023 9:46 amI got the CMS one because of the items you mentioned with visibility and engine access.blueline wrote: Fri Nov 24, 2023 9:40 am
You were able to get a PTScolor! BRG or Irish Green perhaps?
I received a 4RS allocation this past April but passed. They pulled PTS the week before I received notice of the allocation, which was highly irritating (bit not the only reason I passed). Still at the top if another allocation materializes, so I'll decide then. (PTS is back on for 4RS at the moment but has been gone from 911's for quite some time. It's a crap shoot with Porsche...........)
