Southbama
Has thanked: 61 times
Been thanked: 31 times
When I received my Cayman GTS 4.0 2 years ago, I did the "collar mod" on the exhaust valve actuator. It was a pain to install, and a bigger pain to adjust. On a lesser forum, a guy proposed removing one of the 3 nuts on the bottom of the actuator, and installing a threaded rod coupling, and into that a hex head bolt to limit the movement of the actuator arm. Instead of the hex head bolt, I used a large head, knurled thumb screw, making adjustment to suit very simple. It is working well and is very easy to remove if needed. All done in stainless steel of course.
#211
J-Dub
Has thanked: 654 times
Been thanked: 565 times
Bama,
I can envision what you are saying but to you have a picture by chance?
Edit: just saw your post on the other forum. Good work!
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
#212
Has thanked: 932 times
Been thanked: 3990 times
Southbama wrote: Wed Oct 25, 2023 6:40 am When I received my Cayman GTS 4.0 2 years ago, I did the "collar mod" on the exhaust valve actuator. It was a pain to install, and a bigger pain to adjust. On a lesser forum, a guy proposed removing one of the 3 nuts on the bottom of the actuator, and installing a threaded rod coupling, and into that a hex head bolt to limit the movement of the actuator arm. Instead of the hex head bolt, I used a large head, knurled thumb screw, making adjustment to suit very simple. It is working well and is very easy to remove if needed. All done in stainless steel of course.
What is the goal of doing that? If you disconnect the electrical connector going to the solenoid, the PSE flaps will stay open all the time....
#213
Southbama
J-Dub wrote: Wed Oct 25, 2023 8:31 am Bama,
No, but I will take photos and post. I just did this last night after waiting for the thumb screws for 5 weeks.
#214
Southbama
Tom wrote: Wed Oct 25, 2023 9:02 am
Open all of the time is not good, too much drone. This allows me to decide how far it will close to get the sound just right. Same concept as the collars, just easier to adjust and remove if need be.
#215
Southbama wrote: Wed Oct 25, 2023 11:54 am
Ah, that makes sense. Cool!
#216
Southbama
Pictures as requested.
Has thanked: 3289 times
Been thanked: 935 times
My son and I rearranged the 3 car garage to make it a 4 car garage for the Cayman and the Viper ---- quite a nice reptile display, ha!
#218
J-Dub
I enjoyed these two articles, hopefully more to come.
https://motoiq.com/category/projects/porsche/cayman-t/
1957 VW Beetle
2004 VW R32
#219
Has thanked: 4435 times
Been thanked: 2411 times
J-Dub wrote: Thu Nov 02, 2023 6:40 pm I enjoyed these two articles, hopefully more to come.
Very interesting and well thought-out - clearly written too - even though a good bit of what he has done doesn't apply to a GT4. No matter, lots to chew on and learn from!
