I’m debating this right now. I’ve talked to my Porsche mechanic and he’s a fan. Apparently you can take it down about an inch without any problem, but you will likely need an alignment. The wheel well gap is ok but I’d like it tighter and I’m a believer that “altitude is attitude”
Anybody else lowered their car? Any issues?
Lowering your 997
- Comiso-sicily
- Has thanked: 36 times
- Been thanked: 13 times
- GT3Twenty10
- Has thanked: 20 times
- Been thanked: 98 times
It’s way better lowered… also depends on which lowering choice you go. The H&R springs is a safe bet. I had them on my last Porsche…. My new one has coilovers…. Sometimes I like the simplicity of
Just springs.. alignment is forsure or you’ll kill your tires
Current Porsche’s
Both sold:
2010 GT3 (base model)
2008 Cayman CRS 3.8
Both sold:
2008 Cayman CRS 3.8
- Automobilist
- Has thanked: 5 times
- Been thanked: 1 time
It's like 911's were designed to be lowered...
My 991 version was lowered with H&R springs, AND wheel spacers. Really fills out the wheel wells nicely.
What I consider; perfect "stance" for a 911.
What do you think:
What do you think:
- Carrera 3.jpg (2.95 MiB) Viewed 1533 times
- bigdstwinturbo
- Has thanked: 4 times
- Been thanked: 6 times
My 991S has TechArt coils. Subtle lowering but makes a noticeable difference.
- p161463q(10)1697882465.8678002full.jpg (80.4 KiB) Viewed 1524 times
- p161463q(9)1697882465.8678002full.jpg (77.65 KiB) Viewed 1532 times
2014 911 S
2020 Macan S
2014 VW GLI (Unitronic Stage 2)
2020 Macan S
P997-1turbo
- Has thanked: 1 time
I installed H&R coil overs. Dropped it just over an inch.
- IMG_8700.jpeg (3.02 MiB) Viewed 1513 times
- Has thanked: 4439 times
- Been thanked: 2411 times
I think it looks great!Automobilist wrote: Fri Jan 26, 2024 12:20 pm It's like 911's were designed to be lowered...
What do you think:
Yours looks fabulous too!bigdstwinturbo wrote: Fri Jan 26, 2024 12:21 pm My 991S has TechArt coils. Subtle lowering but makes a noticeable difference.
Welcome to Carpokes!
Another good look at lowered! This thread has drawn out some "fill the wheel well" fans, for sure.P997-1turbo wrote: Fri Jan 26, 2024 12:35 pm I installed H&R coil overs. Dropped it just over an inch.
With it lowered an inch, did you experience any fender liner or other tire rubbing while on track?
Tom_N
- Has thanked: 70 times
- Been thanked: 26 times
The US M030 996 sits about an inch higher than ROW spec M030 cars. Is this true for the 997?
Can you simply install ROW M030 spec springs on US M030 cars, or do other bits need replacing too? Anybody done this mod?
2004 40 Jahre #1342
