I need to rewire my mirrors and found all the color codes on the electrical diagram.
Does anyone know where to purchase bulk wires that roughly match the ~15 different wires in the Porsche multi colored scheme?
Thanks!
Where to buy wire?
- Has thanked: 932 times
- Been thanked: 3991 times
I came up with this a while back when I needed a few I couldn't find. There used to be a supplier for color-coded metric wire online in the US but they seem to be out of business. But these days it's very difficult to find metric color-coded wires. You can use SAE wire, but you need to make some compromises on size. 20AWG is a pretty close match for .5mm^2 wire, but 1mm^2 doesn't have a good SAE equivalent. 18AWG is .82mm^2 and 16AWG is 1.3mm^2 (and way bulkier). Lots of charts online to help.
- Drscottsmith
- Has thanked: 3 times
- Been thanked: 15 times
That is genius!
Zirconocene
- Has thanked: 78 times
- Been thanked: 48 times
I bought wire from Sherco. It's not TXL or GXL, but it is marine wire, so even though the insulation layer is a little thicker I think the wire quality is worth it. They didn't have quite all the Porsche colors, but they had quite a number of them.
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
I wasn't aware of Sherco -- looks like a good place to keep in mind, thanks! It's a good point too, to keep in mind the marine and airplane supply places. I end up at West Marine once a year for something. They are the only place I could find with the right sized high-pressure fuel hose for the 944 gas tank for example. The other place I use like that is aircraftspruce.com, which has lots of quirky stuff you won't find at most auto/hardware places, including lots of high-end wire.Zirconocene wrote: Thu Apr 27, 2023 5:12 pm I bought wire from Sherco. It's not TXL or GXL, but it is marine wire, so even though the insulation layer is a little thicker I think the wire quality is worth it. They didn't have quite all the Porsche colors, but they had quite a number of them.
I've checked Digikey and Mouser and some of the other big electronics houses, and no one seems to have a real selection of metric hook-up wire. Digikey has a few metric-sized wires in limited colors but virtually nothing in comparison to its AWG selection. I found an article from 2010 that said US auto makers were adopting ISO 6722 -- a metric standard -- but it seems like the wire-selling world has all but abandoned metric wire in the meantime. Or I'm just googling wrong?Macman45 wrote: Tue May 02, 2023 6:45 am If ok going custom, DigiKey then make everything yourself. I order from them a lot
