Track car prep
chris white
Been thanked: 175 times
Paint has been sprayed!
Thom
The First Carpoke!
Has thanked: 138 times
Been thanked: 153 times
Did you ever experience the front members each living a life of its own when cutting the front cross brace?
'90 944 turbo
#32
Has thanked: 521 times
Been thanked: 264 times
Thanks for the shots with paint...good clear views of interior minus ALL trim and sound deadening....useful for future reference.
chris white
Thom wrote: Fri Jan 06, 2023 8:14 am Did you ever experience the front members each living a life of its own when cutting the front cross brace?
I have seen that done a number of time. Once you are in front of the shock towers there is not much added chassis stiffness so you can end the frame rails there if you want.
#34
Has thanked: 941 times
Been thanked: 4027 times
Very cool pictures. What did you paint it with? I suppose the beauty of a race car is that you can always add structural bracing and cross-members as needed wherever they fit....
#35
chris white
Tom wrote: Fri Jan 06, 2023 10:06 am Very cool pictures. What did you paint it with? I suppose the beauty of a race car is that you can always add structural bracing and cross-members as needed wherever they fit....
its called 'Delfleet Essential' PPG paint. its an epoxy paint designed for 'fleet' use. Meaning that its very tough and affordable! I have used it before and its a very hard finish....but you need to cover everything in a 2 mile radius - it sticks to everything and dries as hard as hell!
#36
chris white
Some more pics if stuff that no one else will ever see….but I know what it looks like!
Much appreciated.
chris white
nice tip from this project - Home Depot has 'generic' tyvek 9' x 150' for about $100. Great to build a temp paint booth by taping it to the ceiling around the car. The Delfleet Essential 2k epoxy paint has a hell of an overspray that is sticky as hell. For a couple of hours after the spray you could hear you shoes sticking to the floor!
#39
chris white
ROB III wrote: Fri Jan 06, 2023 8:53 am Thanks for the shots with paint...good clear views of interior minus ALL trim and sound deadening....useful for future reference.
A lot of brackets, tabs, studs and stuff were removed before paint. amazing how many things were added by Porsche. Probably took of 20lbs in not needed attachment hardware.
#40
