Thoughts on this car?
Has thanked: 942 times
Been thanked: 4028 times
It's local to me and seems underpriced -- right?
https://sfbay.craigslist.org/eby/cto/7543068959.html
Been thanked: 667 times
Tom wrote: Tue Oct 11, 2022 8:58 pm It's local to me and seems underpriced -- right?
Any room in your garage?
Pefa
Has thanked: 68 times
Been thanked: 55 times
Wow that seems like a true bargain! Prices here in Sweden and europe are a lot higher.
If you are looking for a 928 Tom that looks like a very good start!
// Peder
Apparently too good to be true. The ad is still running, but no response at all from the seller. :(
Has thanked: 255 times
Been thanked: 250 times
Great deal if you can connect with the seller. ASSuming the pics and history are good. It's a Cali car so you can look at miles via smog history. Through '88 they still had mechanical odometer with the fragile drive gear. Interior condition is pretty consistent with the miles though. Those are Design 90 option wheels starting a couple years later.
The TLC list includes some intake care including the hoses underneath and probably injectors after sitting so long. Coolant condition is important too. Lots to think about, but from appearances/pics anyway it's certainly worth a look.
SoCal 928 Group Cofounder
dr bob wrote: Thu Oct 20, 2022 7:02 pm Great deal if you can connect with the seller. ASSuming the pics and history are good. It's a Cali car so you can look at miles via smog history. Through '88 they still had mechanical odometer with the fragile drive gear. Interior condition is pretty consistent with the miles though. Those are Design 90 option wheels starting a couple years later.
Thanks. Sadly, no response from the 'seller' despite multiple efforts, so looks like this one is not going to happen. If I end up getting a car from this era, I'd likely refresh lots of that anyway, so a 50k car for that price seemed like a no brainer -- but it looks like the hunt goes on. :( Great tip on verifying miles via CA smog reports though! I'll remember that one.
As for the odometer gear, I have that covered many times over. I designed our own Carpokes version of the 944 gear, which some of the 928's use as well. When I order the fancy resin to make these, I made probably 100 gears since the resin had to be used within a month or so before it expired... I guess they varied by year, but have printer/will travel. :)
viewtopic.php?f=20&t=900
Lowencash
Has thanked: 38 times
Been thanked: 19 times
If it is indeed under-priced (and I'm inclined to think it is), perhaps the seller will respond to an email that includes a 'better' offer.
