Hey all,
Wrapping up a mini restoration on my car, and one of the interior projects included restoring the gear shift knob.
When I purchased the car in 1999, the original shift knob had already been replaced with a knob from a 993. Over the years, it started showing some wear and tear, so I figured I would restore it and change out the cap to one with the proper shift pattern as well as change up the color.
I thought this would be simple, but it turned into a lengthy and costly project. Just getting the cap off the knob was a nightmare. The next hurdle was finding a non-6 speed cap that would fit; it turns out they just don't exist. Everything I found was too small in diameter.
To solve it, I went to a local metal shop and had them fabricate a custom spacer/ring to fit right around a 944 cap. This worked out perfectly. I then took the parts to a metal finishing shop and had everything anodized with a grey finish to match the car's exterior.
I wasn't expecting this to be such a challenge, but I'm very pleased with the results. It was absolutely worth the time and effort!
Shift Knob Restoration…Ugh!!
- PXL_20260524_182503000~2_Original.jpeg (1.49 MiB) Viewed 70 times
- PXL_20260712_225252987_Original.jpeg (1.72 MiB) Viewed 70 times
- PXL_20260712_215833475~2_Original.jpeg (1.04 MiB) Viewed 70 times
- PXL_20260712_215648865~2_Original.jpeg (1.41 MiB) Viewed 70 times
- PXL_20240125_011712275_Original.jpeg (2.21 MiB) Viewed 70 times
- PXL_20240125_012137958_Original.jpeg (2.15 MiB) Viewed 70 times
- PXL_20240202_211903685_Original.jpeg (2.3 MiB) Viewed 70 times
- PXL_20240202_212003246_Original.jpeg (2.42 MiB) Viewed 70 times
- PXL_20240202_213314154_Original.jpeg (2.18 MiB) Viewed 70 times
1986 951
2007 RS4
1964 Falcon Sprint
2007 RS4
1964 Falcon Sprint
- Has thanked: 4516 times
- Been thanked: 2450 times
It looks great!
Sometimes (maybe too often), the simplest tasks turn into the biggest headaches - the hanging thread that continues to unravel.
However, the satisfaction of successfully completing whatever was being attempted makes it all worthwhile. Usually.
chrischrischris
- Has thanked: 7 times
- Been thanked: 35 times
That does look nice. I also like the leather trimmed console. Was that a factory or custom job?
The shift boot looks different than others I've seen in a 994. Is that the 993 style?
It was a factory option (M981) but my car did not come with it. I restored the interior and had Classic 9 cover the dash, door panels and console. Wanted to retain the factory look.chrischrischris wrote: Fri Jul 17, 2026 5:51 am That does look nice. I also like the leather trimmed console. Was that a factory or custom job?
Yes, it's from a 993 C2S.chrischrischris wrote: Fri Jul 17, 2026 5:51 am The shift boot looks different than others I've seen in a 994. Is that the 993 style?
1986 951
2007 RS4
1964 Falcon Sprint
2007 RS4
1964 Falcon Sprint
