944 Turbo DIY TunerPro Chips
pizatski
Has thanked: 38 times
Been thanked: 18 times
Just dropping in to say a huge thank you for all of the tuning information, guide, chip info, XDFs, and BINs - I was able to decode what this Max DME III chip was actually doing and I was able to successfully program a PicoRom EEPROM emulator with a custom tune to start dialing in my modified 944 Turbo! This is turning into a really fun, and meaningful, project for this web engineer.
Next steps are getting an analog-to-digital DAQ so that I can start gathering data and telemetry from the car and wideband while tuning it.
For background, I got started down this bit of a rabbit hole because I blew the head gasket on track at Road America last year and thought it might have something to do with the combination of unknown chip, aftermarket mods, and lower octane gas the 2nd day causing knock. After looking at the timing advance and fueling maps in this aftermarket chip, I was getting away with it. Now, I'll be able to really dial in the setup for reliability and power.
PXL_20260306_205711429 (1).jpg (1.82 MiB) Viewed 396 times
- Patrick S.
1986 944 Turbo
2011 VW Touareg TDI
PCA Chicago Region
#71
Has thanked: 947 times
Been thanked: 4040 times
pizatski wrote: Fri Mar 06, 2026 1:15 pm Just dropping in to say a huge thank you for all of the tuning information, guide, chip info, XDFs, and BINs - I was able to decode what this Max DME III chip was actually doing and I was able to successfully program a PicoRom EEPROM emulator with a custom tune to start dialing in my modified 944 Turbo! This is turning into a really fun, and meaningful, project for this web engineer.
Awesome -- once you have access to the maps like that, you'll never go back to off-the-shelf chips! Does that emulator work with TunerPro RT to allow for real-time map edits?
#72
pizatski
Thanks, Tom. I agree completely - I won't be going back.
The emulator doesn't work natively with TunerPro RT, but it does have a fairly simple command line interface. The workflow looks something like this:
1) Install pre-requisites (TunerPro or TunerPro RT) and the picorom CLI
2) Open the appropriate BIN in TunerPro with the appropriate XDF (in my case, the 28 pin configuration)
3) Make changes, save them
4) Use the picorom CLI in the command line tool of your choice (Powershell for me) to upload the BIN you just modified to the picorom in 64kbit mode which is what the DME expects
5) Test on road or dyno, continue modifying tune as needed
6) Commit it to the onboard flash if you want it to persist after the picorom is powered off
Steps 2 - 5 can be done with the car running and the laptop connected to the picorom while installed in the DME. When updated, changes take effect immediately in the car so you can tune on the fly. When committing to flash, the chip is power-cycled and the car shuts down so that's more of a last step after tuning session type thing to live with what you just did until you burn an EEPROM.
I haven't dug into it much, but I'd imagine it wouldn't be too difficult to make a plugin or script with TunerPro which would upload to the picorom upon save immediately.
- Patrick S.
1986 944 Turbo
2011 VW Touareg TDI
PCA Chicago Region
#73
Meine44
Been thanked: 6 times
These DIY chips are very intriguing. I wonder if this would be the best route to update my Autothority MAF that came on my 1988 951 when I bought it.
What is the best way to read the Autothority chip to get a baseline of the current tune?
Does the TunerPro RT software require a laptop to be plugged in as the car is driven in order to log real-time data?
#74
Meine44 wrote: Wed Jun 24, 2026 10:40 am These DIY chips are very intriguing. I wonder if this would be the best route to update my Autothority MAF that came on my 1988 951 when I bought it.
Autothority moved the map locations around on its normal performance chips, so I'd image they did the same on their MAF chip. As such, the XDF files available here (and elsewhere) won't work for any map that's been moved. It's not impossible to find them, but you'd need to spend time hunting down the maps of interest and building your own XDF file for it. Or ditch the APE MAF and go back to the AFM or MAF that uses more standard chips.
#75
markagsmith5
Has thanked: 9 times
Been thanked: 30 times
Interesting the mention of the "Autothority MAF " I didn't realise that such a thing existed. I have just posted details of a project I have been working on viewtopic.php?t=5337
Maybe I should have searched to see if such a product already existed. Regardless, it was an interesting project and things like that keep me busy in retirement.
1987 944 Turbo
2024 BYD Seal Premium
#76
Meine44
Tom wrote: Wed Jun 24, 2026 6:31 pm
Sounds like the best course of action is to update the MAF (leaning toward Vitesse) and then use this DIY TunerPro method to continue tuning.
#77
Meine44 wrote: Thu Jun 25, 2026 6:37 am
The Vitesse MAF is the best available in my opinion, but it uses a proprietary chip board with active electronics that replaces the standard chip. The tune is excellent so no need to edit, but there's no practical way to edit the tune yourself with that MAF. Lesser MAF conversions use traditional chips you can tune, but only Vitesse (and the NLA m-tune) rewrote the DME code to read the native MAF input. The others are a compromise in that they try to tune around the fact that the MAF is a fundamentally different input than the factory AFM.
#78
markagsmith5 wrote: Wed Jun 24, 2026 9:21 pm Interesting the mention of the "Autothority MAF " I didn't realise that such a thing existed. I have just posted details of a project I have been working on viewtopic.php?t=5337
They haven't been available since the Sydney Olympics. :shifty: There are a few other MAF conversions available these days, but I'd say your project was time very well spent either way.
#79
vacobra
Tom wrote: Wed Dec 10, 2025 8:05 am This reminds me, I'd like to find a volunteer or three to test out my baseline performance chip for the 951. Only catch is we'd need a stock car with wideband (and preferably a boost controller) so we can log the AFR and fine tune as needed. If you have or know of anyone with a stock 951 who might be interested, please let me know! I'd supply the chips for free, and dial them in based on the wideband logs. I'll even throw in a pre-wired knock counter to add more data to the mix and make it worth you while!
Tom did you find anyone? I wouldn’t mind being a volunteer I have a manual boost controller, boost gauge, and an arm series x wideband installed.
