Rear Seat Delete
Hey Guys Here’s the final version of my Rear Seat Delete, This is my first time trying to post a photo so bear with me…
- Rear Seat Delete
- IMG_5613.jpeg (3.29 MiB) Viewed 114 times
- IMG_5612.jpeg (2.9 MiB) Viewed 114 times
Looks very nice, great work. An optional visual improvement to consider would be to get a stainless press-fit stud going through the top of the bar, and fastening with nut and washer on the underside. Leaves just a small flat disk visible, getting rid of the cap nut sticking up.
- Has thanked: 951 times
- Been thanked: 4073 times
Looks great. And probably a lot less noisy than my shell...
spacecad3t
- Has thanked: 89 times
- Been thanked: 72 times
If you want quicker access to the fire extinguisher without adding bulk, Id recommend the element fire extinguisher with their cage mount, you could mount it to that rail you installed.Trouble wrote: Wed Jul 15, 2026 7:29 pm I’m putting a small Harbor Freight tool kit in there along with a fire extinguisher and some miscellaneous stuff that I think I may need…![]()
